Spare key
Spare key
Postby Gary66 » Mon Aug 14, 2017 1:22 pm
Looking to get a spare key cut for my 98 mk2, have not had any joy, went to timpson guy had to send away for one but was no use, car was imported so do the know if that makes any difference. Any ideas, will I have to contact Mazda?
Gary66
Re: Spare key
Postby drumtochty » Mon Aug 14, 2017 6:16 pm
Not if you are prepared to explain what the problem is with the key Timpsons provided.
Did it fit in the ignition barrel.
If it did, then did it not turn the lock barrel or not.
If it did, did the car not start.
Can you confirm that the car is a Mazda Roadster imported from Japan and was previoisly used in the Japanese Domestic Market.
Re: Spare key
Postby Gary66 » Mon Aug 14, 2017 7:24 pm
Boy started to cut it but certain bits of the new key were not the right size so never even got the key.
Boy I bought it from said it was imported, has the Japanese tax disc and that on it and Japanese writing on all labels etc etc
Gary66
Re: Spare key
Postby drumtochty » Mon Aug 14, 2017 9:11 pm
Pain in the backside but you need to get the lock barrel out the righthand door and get the key number off it.
Then go to this webpage and order a key from autolink.
There may well be others who can do this for you!
http://www.autolinkmx5.com/key-mx-5-cut ... 2320-p.asp
or you can just get a blank and have your key copied.
http://www.autolinkmx5.com/key-blank-mx ... 8563-p.asp
Or it may just be as easy as the part number is shown to order off Mazda.
Re: Spare key
Postby Gary66 » Tue Aug 15, 2017 9:57 am
Cheers mate, probably go with the 2nd option and get the key cut from my original, seems a lot easier.
Gary66
Re: Spare key
Postby Gary66 » Tue Aug 15, 2017 12:28 pm
Just noticed there is a number engraved on the key 11983 you think that's significant?
Gary66
Re: Spare key
Postby Enjay » Tue Aug 15, 2017 2:39 pm
Keys can often be ordered from the manufacturer if you know the key number. It's quite likely that's the number you're looking for. Worth a phone call to your dealer at least.
Enjay
Re: Spare key
Postby drumtochty » Tue Aug 15, 2017 3:15 pm
These guys say they can do it. They say up to 1995 but if they are a lot cheaper than the price you get from Mazda worth a shot.
https://keysinthepost.com/product/mazda ... c-car-key/
Re: Spare key
Postby Gary66 » Tue Aug 15, 2017 6:19 pm
Thanks for the help guys
Gary66
