Front Chassis Rails on Mk2.5
Re: Front Chassis Rails on Mk2.5
Postby kpdornan » Sun Sep 04, 2016 7:44 am
Other side just as bad
kpdornan
Postby kpdornan » Sun Sep 04, 2016 7:45 am
Bye bye bad stuff
kpdornan
Postby kpdornan » Sun Sep 04, 2016 7:46 am
Top team at work
kpdornan
Postby kpdornan » Sun Sep 04, 2016 7:47 am
New panels going in, got from MX5 Restorer
kpdornan
Postby kpdornan » Sun Sep 04, 2016 7:49 am
One liberal coating in seal sealant, anti rust primer and under seal later, it almost looks the same as before!!
kpdornan
Postby kpdornan » Sun Sep 04, 2016 7:50 am
And it all went back together, eventually!!
kpdornan
Postby kpdornan » Sun Sep 04, 2016 7:54 am
An excellent 2 days work.
Will be booking some more time at Ramp It Up to take both front wings off and remove the flower beds from behind them, before treating the visible surface rust and dealing with what I can't see.
Stone chip to bottom sections and tidy up the flaking paint around the arches. Replace top wishbones if I have time.
Will be good to get all the rust dealt with before moving onto suspension.
kpdornan
Postby IanH » Sun Sep 04, 2016 8:19 am
Looking good :D
Postby Telly Addict » Sun Sep 04, 2016 11:11 am
Good job!
Postby Zeolite » Sat Nov 12, 2016 1:07 pm
Looks identical to what we just fixed on the Nevada. We couldn't find a part so just fabbed up some steel and welded it in. I am taking it that this is common on MX5s?
Zeolite
Postby drumtochty » Sat Nov 12, 2016 2:07 pm
Plenty of repair panels available both from MX5 Restorer and Mazda Menders.
Postby Zeolite » Tue Nov 15, 2016 1:43 pm
Ha! Too late. Dad did a nice job with some sheet metal and the mig.
Might need some of those rear panels though.
Zeolite
Previous
