Front Chassis Rails on Mk2.5
Postby kpdornan » Wed Aug 17, 2016 12:40 pm
Dear all and especially owners of mk2.5.
Have recently checked under the engine tray on my 2003 mk2.5
The amount of corrosion on the front chassis rails is frightening.
I would advise everyone to have a look as soon as possible as it's never going to get better, only worse.
MX5 restorer has the repair parts for approx. £140.
Only good I would guess as long as you have enough good metal left to fix.
I will be having my car at Ramp It Up in Arbroath for a couple of days at the end of the month to:
1/ learn how to remove all the required parts before the next days welding
2/ have my fingers crossed that all the bolts behave, I see a lot of plus gas being used over the next week or so in prep
3/ underseal the life out of everything before driving away happy, I hope
Any thoughts or advice anyone can offer would be greatly appreciated.
regards
Kevin
kpdornan
Re: Front Chassis Rails on Mk2.5
Postby Telly Addict » Wed Aug 17, 2016 1:09 pm
My advice would be to budget extra time, just in case...oh and keep cutting the rotten stuff away until you get to solid metal. You can always get the whole chassis beam assy complete if necessary.
I had a similar issue a few months ago, see my thread here.
00 Mk2 1.8 SE BRG / Tan
Telly Addict
Postby drumtochty » Wed Aug 17, 2016 2:32 pm
There are two places to get the repair panels.
The one you mentioned that do an L shaped panel outside face and underside panel and as an extra a mini inside face.
Wayne on the Mazda Menders board does a U shaped panel that is outside, underside and inside face in one panel. Similar price if I remember.
The guy at Ramp up can mig weld and he also has access to a very good fabricator welder if he considers it beyond him but I rate his welding ability.
Postby kpdornan » Wed Aug 17, 2016 4:14 pm
Thanks both.
Neil is getting his welder from Aberdeen down to do the job on the Saturday.
Hopefully I can get it prepped on the Friday.
kpdornan
Postby drumtochty » Wed Aug 17, 2016 5:59 pm
To be honest any welder will probaly re prep it because the just do!
What time is he starting on Wednesday as I may well come down and get some tips for doing it myself or not after I watch him.
Postby kpdornan » Wed Aug 17, 2016 6:47 pm
Hi
doing the welder first thing Saturday 27th
kpdornan
Postby drumtochty » Wed Aug 17, 2016 11:06 pm
Hope to see you then.
Postby kpdornan » Sun Aug 21, 2016 8:55 am
I have got the two long bolts for wishbone and nuts for when the original ones won't come out. Which other ones would be recommended to have in case of rusted parts. Getting confused with adjustment bolts camber bolts etc.
Kevin
kpdornan
Postby drumtochty » Sun Aug 21, 2016 9:22 am
The camber adjustment bolts can be handy, MX5parts have them.
If I turn up I will bring some camber adjusting bolts with me.
Postby kpdornan » Sun Aug 21, 2016 9:56 am
Thanks Eddie,
What about the bolts that fix the bottom end of the shocks?
Toying with the idea of doing the bushes at the same time since Neil has a 20 ton press, seems like common sense.
kpdornan
Postby drumtochty » Sun Aug 21, 2016 12:44 pm
Autolink will have them but watch the postage costs
Mx5parts also
http://www.mx5parts.co.uk/lower-shock-a ... p-419.html
Postby kpdornan » Wed Aug 24, 2016 11:41 am
hi Eddie,
turns out neils welder won't be doing job now.
Neil will be doing the welding so not sure if it would be done Friday or Saturday.
Just thought I would let you know since you said you might come down on the Saturday to watch.
Maybe check with Neil?
regards
Kevin
kpdornan
Postby drumtochty » Wed Aug 24, 2016 5:03 pm
Not a problem and I have seen Neil's welding and it is good quality.
Postby kpdornan » Sun Aug 28, 2016 9:04 am
Job done, pictures to follow soon once I master how to.
Car now structurally sound, brilliant job by Neil at Ramp It Up in Arbroath.
I would recommend him to anyone.
Kevin
kpdornan
Postby drumtochty » Sun Aug 28, 2016 12:25 pm
Yes, I went down to the job on Saturday when one side had been done and great job done at Neil's.
It's getting to the point where this is the just one of the jobs that has to be done in the life of a Mk2/Mk2.5.
Postby kpdornan » Sun Sep 04, 2016 7:37 am
Thought I would post some pictures of the process, remember that this had passed its MOT with no advisories
kpdornan
Postby kpdornan » Sun Sep 04, 2016 7:39 am
Other side
kpdornan
Postby kpdornan » Sun Sep 04, 2016 7:41 am
From underneath
kpdornan
Postby kpdornan » Sun Sep 04, 2016 7:42 am
kpdornan
Postby kpdornan » Sun Sep 04, 2016 7:43 am
Slight tap with a nylon hammer later
kpdornan
Next
Users browsing this forum: Majestic-12 [Bot] and 3 guests
