Gearbox oil change
Gearbox oil change
Postby kpdornan » Tue Jun 21, 2016 11:59 am
I will, hopefully, be attempting my first gearbox oil change this weekend and am looking for some tips on how to get the best access to the drain/fill plugs.
I have a 2003 1.8 svt.
have had a look underneath and I am presuming that there are a couple of bits to remove first.
Anyone got any pics to help me on my way?
thanks
Kevin
kpdornan
Re: Gearbox oil change
Postby attila » Tue Jun 21, 2016 1:30 pm
attila
Charlie Grant
Postby gm » Tue Jun 21, 2016 1:39 pm
I have used one of these to refill the diff and gearbox in the past but recently tried the hose / funnel trick in the link above which was much easier :)
http://www.screwfix.com/p/hilka-pro-craft-oil-suction-gun-500cc/12527
also have a look at
http://www.miata.net/garage/trans/everything.html
Postby OldSpice » Tue Jun 21, 2016 4:19 pm
We all love either.....
Castrol Syntrans Multivehicle 75W/90 GL4 or Redline MT90 :wink:
Postby drumtochty » Tue Jun 21, 2016 4:45 pm
If you want bring it up to Drumtochty and use my Two Post Lift and large oil syringe. You can also get better access to underneath to check various bits and touch up the underseal.
I have a tender shoulder so will be in supervision mode only bring overals
If it is 5 speed get 2 litres and if it is a 6 speed you need three litres as they usually use a bit more than 2 litres but if you bring it up I will have a half litre or so of the multivehicle.
The stock it at Halfords Dundee and Arbroath.
Postby drumtochty » Tue Jun 21, 2016 8:43 pm
The car has a six speed and it is easy to destroy the box if you remove the wrong bolt.
http://www.miata.net/garage/tsb/s05_112_02.html
Postby kpdornan » Wed Jun 22, 2016 9:06 am
that would be great, thanks very much for the offer.
I have 3 litres of the oil already so should be ok on that front.
Is there a particular day that suits?
I'm away in Aberdeen all day Saturday free Sunday or possibly next weekend?
thanks again
Kevin
kpdornan
Postby drumtochty » Wed Jun 22, 2016 10:39 am
I will get back to you on the day later.
Postby drumtochty » Wed Jun 22, 2016 7:33 pm
Sunday is fine any time from 10am on.
PM sent with instructions.
Postby kpdornan » Mon Jun 27, 2016 7:37 pm
Hi Eddie,
many thanks again for all the help.
The ABS light went out the second I drove through your gate!!
Not to be seen since.
regards
Kevin
kpdornan
Postby drumtochty » Mon Jun 27, 2016 7:55 pm
Sorted and the underneath of the car is now in a better state.
Good result in the end.
Users browsing this forum: Google [Bot] and 6 guests
