Rear sills
Rear sills
Postby WGL63 » Fri May 13, 2016 5:32 pm
My mk2 iccon in getting rear springs and found rear sills are rotten. Should I repair or scrap?
Car due MOT next month. Live in Falkirk
Any advice?
William
WGL63
William Lindsay
Re: Rear sills
Postby OldSpice » Fri May 13, 2016 5:53 pm
No right or wrong answer, only differing opinions.
Do them right, call it around £400.00 a side with new metal as opposed to balls of Daily Record & filler.
Is it worth it to you?
Before you make up your mind check your front chassis rails in the engine dept have not progressed to the appearance of brown elemental cheese.
Do that by removing the drip tray and belting them with a very big hammer....aka a BFH..and poke them with a very big screw driver.
Preferrably while in a bad temper.
They could be the decider.
Re: Rear sills
Postby drumtochty » Fri May 13, 2016 6:20 pm
+1
Re: Rear sills
Postby OldSpice » Fri May 13, 2016 6:35 pm
I'm in Falkirk too incidentally.
I've been there twice where you are at the moment.
If you want, how about a coffee at Teresa's Burger van opposite St Mungo's High and I'll have a look at the car?
Re: Rear sills
Postby OldSpice » Sat May 14, 2016 10:59 am
PM'd you back William.
For your benefit, this is typical of that (our) marque these days.
Rotted chassis rails.
And this is the issue..double skin construction ( read moisture trap)
Oh well...new ones!
:shock:
Strange is it not..since Mazda claimed galvanisation that did not exist.
These brochures were withdrawn pronto from showrooms.
Wonder why? :roll:
