Heads up! Halfords Professional 200 piecel Socket offer
Postby 71NotOut » Thu Jan 14, 2016 2:15 pm
Heads up!
Halfords 200 piece professional socket set down to £135 from £300.
Another 10% off from 12-2 today so brings it down to £121.50.
Lifetime warranty as well!
http://www.halfords.com/webapp/wcs/stor ... &langId=-1
I've reserved one for pick up tonight.
Re: Heads up! Halfords Professional 200 piecel Socket offer
Postby drumtochty » Thu Jan 14, 2016 5:33 pm
They get a good name for advanced home mechanics and pro's starting off in the trade.
As you say if it breaks they replace the part!
Postby joeytalent » Thu Jan 14, 2016 9:02 pm
drumtochty wrote:They get a good name for advanced home mechanics and pro's starting off in the trade.
The warranty doesn't apply to the ratchet I believe.
I have two halfords professional sets, always been very happy with the quality / cost.
Postby drumtochty » Thu Jan 14, 2016 10:10 pm
It does if the handle breaks but as you say if it is the clicky bit they sell a repair kit.
A time served mechanic is told to crack or finaly tighten a bolt with the tommy or breaker bar and only to loosen and tighten to a resonable degree with a ratchet.
Also not to hammer the end of a screwdriver but I have lots of screwdrivers like that.
Postby 71NotOut » Fri Jan 15, 2016 1:20 am
I've heard reports of variable success with replacement ratchets when they have broken. Seems to be very staff dependant!
Sent from my SM-T810 using Tapatalk
Postby stugee » Fri Jan 15, 2016 10:28 am
I had both my 3/8 and 1/4 drive ratchets replaced at 2 different halfords in Aberdeen, no quibble.
The 1/4 wouldn't move either way, suspected water ingress, I was in and out in 5 minutes with a new ratchet. The 3/8 had an intermittent fault where the direction switcher would stick. The guy said he'd fit a repair kit. Opened up then just went and got me a new ratchet.
Can't fault the service!
stugee
