mx5 mk3 brakes and clutch help !!
Postby callum22 » Thu Jan 14, 2016 11:31 am
Hi all
had new brake pads and clutch slave cylinder fitted,
brakes and clutch feel spongy
had master cylinder and servo checked out all fine
had them both bled twice and no change any ideas ????
callum22
Re: mx5 mk3 brakes and clutch help !!
Postby drumtochty » Thu Jan 14, 2016 11:48 am
There is still some air in the system as the same reservoir does both jobs.
I had a similar problem with our Jeep and after lots of tries a bubble of air came out one of the rear cylinders.
Sorted!
