mx5 mk3 condensation boot lid
Postby callum22 » Fri Nov 06, 2015 8:54 pm
Hi guys had an issue for a couple weeks now as its got into winter and the moisture has been bad recently, i've got condensation on the inside of the boot lid and my rear lights fog up also, i have a hard top on the car and have done so for 2 years,
the boot is completely dry even under carpets, i have dried out the boot previously last week but still im getting moisture
maby boot seal ??
do rear lights have seals around them ??
help much appreciated
update 19/11
changed boot seal no luck still condensation, think its a bung letting in moisture under the boot carpet
callum22
Re: mx5 mk3 condensation boot lid
Postby brez » Sun Feb 28, 2016 10:59 pm
Hi Callum,
I have the same issue, as far as i can see there are no broken seals or any obvious ways for water to get in.
As a stop gap measure i picked up a car Air Dry car dehumidifier from halfords for £7.50 and it seems to have cut out the condensation completely.
brez
Postby moontune » Sun Feb 28, 2016 11:55 pm
Rear lights have seals that go. Common problem.
Sent from my XT1039 using Tapatalk
moontune
Ed Duddy
Postby moontune » Sun Feb 28, 2016 11:56 pm
moontune wrote:Rear lights have seals that go. Common problem.
Just read you have mk3. Not sure about lights on those. Mine is a mk1
moontune
Ed Duddy
Postby drumtochty » Mon Feb 29, 2016 12:00 pm
There is a gasket on the two number plate lights but as they are horizontal maybe not the problem.
There is no gasket between the body and the rear light clusters on the rear lights.
Mazda parts diagram attached.
If the car is a soft top have you cleared the rear cabin drains.
Postby OldSpice » Tue Mar 01, 2016 6:26 pm
Once it's sorted, don't store pressurised cans in boot.
They promote condensation...for some scientific reason beyond me.
Postby IanH » Tue Mar 01, 2016 6:49 pm
OldSpice wrote:Once it's sorted, don't store pressurised cans in boot.
Ooh, a lot of people store tyre weld or other brands of tyre repair gloop in there.
