Retro-fitting Mk2.5 Parts in MK2
Postby Telly Addict » Tue Oct 20, 2015 11:39 pm
Hi, can anyone tell me what parts from a MK2.5 will fit a MK2? For example, are the light clusters interchangable, front and rear?
00 Mk2 1.8 SE BRG / Tan
Telly Addict
Re: Retro-fitting Mk2.5 Parts in MK2
Postby drumtochty » Wed Oct 21, 2015 12:07 am
So you have must the brakes and the performance problems sorted.
Postby Telly Addict » Wed Oct 21, 2015 10:42 am
drumtochty wrote:So you have must the brakes and the performance problems sorted.
Well as it happens, both appear to have responded well to an Italian tuneup although I'm still awaiting plugs, leads and air filter arriving from mx5parts, but thanks for asking.
While I'm waiting though I'm exploring other areas of tinkerdom, so back to my original question...
Telly Addict
Postby Telly Addict » Wed Oct 21, 2015 9:16 pm
Found part of the answer here http://www.mx5nutz.com/forum/index.php?showtopic=147249. Short answer; the rears are interchangeable with minor modification.
Telly Addict
Postby Telly Addict » Tue Oct 27, 2015 8:33 pm
Telly Addict wrote:Found part of the answer here http://www.mx5nutz.com/forum/index.php?showtopic=147249. Short answer; the rears are interchangeable with minor modification.
In actual fact, no modification required at all; straight swap. 8)
Not sure if it's because mine is a 99/00 model.
Telly Addict
