MOT history website
MOT history website
Postby iain cooper » Mon Oct 19, 2015 9:07 am
I thought this was an interesting site, great to look up your old vehicles.
https://mot-history.net/
Re: MOT history website
Postby IanH » Mon Oct 19, 2015 12:31 pm
That is interesting, here's my first MX-5 which I bought new in 2004, it looks like corrosion has ultimately done for it.. :(
Mileage readings are currently only available for MOTs done from 1 August 2011.
Vehicle make MAZDA Vehicle model MX5 Date first used 16 April 2004 Fuel type Petrol Colour Blue
MOT history of this vehicle
Test date 24 June 2015 Test Result Fail Odometer reading 79,472 miles MOT test number 2058 8577 5193 Reason(s) for failure
Offside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Nearside Rear Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Offside Rear Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Nearside Front Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
Advisory notice item(s)
Nearside Rear Seat belt anchorage prescribed area is corroded but not considered excessive (5.2.6)
Nearside Front Suspension arm corroded but not seriously weakened (2.4.G.1)
Offside Front Suspension arm corroded but not seriously weakened (2.4.G.1)
Nearside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
n/s-o/s chassis legs corroded
n/s/r-o/s/r wheel arches corroded
Test date 2 May 2014 Expiry date 1 May 2015 Test Result Pass Odometer reading 78,264 miles MOT test number 1383 1252 4199 Advisory notice item(s)
Nearside Front Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
Offside Rear Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
Test date1 May 2014 Test ResultFail Odometer reading78,264 miles MOT test number7550 3112 4116 Reason(s) for failure
Rear Brake pipe excessively corroded (3.6.B.2c)
Test date 2 May 2013 Expiry date 1 May 2014 Test Result Pass Odometer reading 76,087 miles MOT test number 3251 6212 3102 Advisory notice item(s)
Offside Front Brake pipe slightly corroded (3.6.B.2c)
Nearside Brake pipe slightly corroded (3.6.B.2c)
Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Nearside Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Offside Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Test date 30 April 2012 Expiry date 29 April 2013 Test Result Pass Odometer reading 71,769 miles MOT test number 9696 2132 2105
Test date20 April 2011 Test ResultFail MOT test number8460 4091 1142 Reason(s) for failure
Nearside Front Front position lamp(s) not working (1.1.A.3b)
Test date20 April 2011 Expiry date19 April 2012 Test ResultPass MOT test number8189 4011 1155
Test date13 August 2010 Expiry date12 August 2011 Test ResultPass MOT test number2744 2532 0225
Test date26 June 2009 Expiry date25 June 2010 Test ResultPass MOT test number3907 7737 9103
Test date17 April 2008 Expiry date16 April 2009 Test ResultPass MOT test number4314 4890 8104
Test date11 April 2007 Expiry date16 April 2008 Test ResultPass MOT test number9749 1120 7190 Advisory notice item(s)
Front Brake pad(s) wearing thin (3.5.1g)
Nearside Inner Front brake disc slightly pitted (3.5.1h)
Offside Inner Front brake disc slightly pitted (3.5.1h)
Postby 71NotOut » Mon Oct 19, 2015 1:23 pm
A lot of my ex-cars don't appear on there and I would have expected them to!
They can't ALL have been scrapped, could they? :D
Postby OldSpice » Tue Oct 20, 2015 9:42 am
This bit amused me about our Sport......
Nearside Rear Body has slight corrosion (6.1.B.2)
Offside Rear Body has slight corrosion (6.1.B.2)
Both front tyres scrubbed slightly
Nah...really? I'd never have known! :evil:
Postby OldSpice » Tue Oct 20, 2015 9:47 am
And for the Mk1....
Vehicle make MAZDA Vehicle model MX-5 Date first used 31 December 1993 Fuel type Petrol Colour Green
Test date 12 January 2015 Expiry date 11 January 2016 Test Result Pass Odometer reading 209,345 miles MOT test number 4191 4241 5007 Advisory notice item(s)
Front coil spring corroded (2.4.C.1b)
Under-trays fitted obscuring some underside components
Items removed from driver's view prior to test
Test date 10 January 2014 Expiry date 9 January 2015 Test Result Pass Odometer reading 193,184 miles MOT test number 7458 0061 4043 Advisory notice item(s)
Oil leak
Test date 3 August 2012 Expiry date 2 August 2013 Test Result Pass Odometer reading 182,810 kms MOT test number 2898 7651 2275 Advisory notice item(s)
Rear Sub-frame corroded but not seriously weakened (2.4.G.1)
Nearside Suspension component mounting prescribed area is distorted but not considered excessive (2.4.A.3)
Offside Rear Lower Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Oil leak
Test date 6 May 2011 Expiry date 5 May 2012 Test Result Pass MOT test number 2089 5682 1452 Advisory notice item(s)
Fuel pipe/s corroded
n/s sill slit damage
Test date 5 May 2011 Test Result Fail MOT test number 5386 1532 1149 Reason(s) for failure
Brake pipe leaking (3.6.A.1)
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.3)
Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.3)
Test date 30 April 2009 Expiry date 29 April 2010 Test Result Pass MOT test number 6126 4052 9108 Advisory notice item(s)
Rear Brake pipe slightly corroded (3.6.B.2c)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Test date 30 November 2007 Expiry date 29 November 2008 Test Result Pass MOT test number 3902 5453 7374 Advisory notice item(s)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
Oil leak
Test date 8 November 2006 Expiry date 7 November 2007 Test Result Pass MOT test number 1809 4271 6381
Test date 7 November 2006 Test Result Fail MOT test number 6633 2141 6309 Reason(s) for failure
Offside Rear fog lamp missing (1.3.2a)
Rear fog lamp tell tale not working (1.3.1b)
Rear fog lamp switch faulty (1.3.1a)
Miles ought to be in kilometers by the way...but I guess by the time you exceed 150,000 of them...does it matter? :lol:
Postby 71NotOut » Tue Oct 20, 2015 10:34 am
GSG641T - Talbot Horizon - No vehicle that matched the data you entered could be found.
RMS291M - Mini 850 - No vehicle that matched the data you entered could be found.
TDS842W - Vauxhall Chevette - No vehicle that matched the data you entered could be found.
DSF769S - Mini 1000 - No vehicle that matched the data you entered could be found.
A511WUS - Cavalier SRI - No vehicle that matched the data you entered could be found.
B333JSX - Fiesta XR2 - No vehicle that matched the data you entered could be found.
YGB9S - MG BGT - No vehicle that matched the data you entered could be found.
D283YSX - MG Metro - No vehicle that matched the data you entered could be found.
G717ECS - Vauxhall Astravan - No vehicle that matched the data you entered could be found.
M354TBM - Vauxhall Cavalier 2.0 16V - last MOT 2008
P116HSL - Mitsubishi Shogun 2.8 TD - last MOT 2009
NPD348L - MG BGT - last MOT 2015 - yay, still going!! :lol:
P493HMS - Honda Prelude 2.2 VTEC - last MOT 2011
G761PKS - Peugeot 405 GRD - last MOT 2005
N414HCS - Honda Accord Coupe - last MOT 2013
R631FGG - Volkswagen Golf VR6 - last MOT 2009
W778JSF - Ford Focus 2.0 Zetec - last MOT 2013
DK53VFO - Skoda Octavia vRS - last MOT August 2014
SP03OMA - Mazda MX5 Montana - still going!! :lol:
F2SAH - Skoda Fabia vRS - still going.
EG53CSY - Ford Mondeo Ghia X - still going.
F2SAH - Mazda CX-7 - still going.
J54LAT - Eunos Roadster - still going.
So 6 out of my previous 23 cars still going according to that site! Hopefully not an indication of how I look after my cars :D
Postby OldSpice » Tue Oct 20, 2015 10:49 am
It does not bode well for your 5. I'll give you a tenner for it and save it.
Talbot Horizon? I remember that. King of the terminal understeerer! :lol:
Postby OldSpice » Wed Oct 21, 2015 9:39 am
Furthermore, it's the first time I've seen the "obscuring" :wink: undertray mentioned.
"Under-trays fitted obscuring some underside components"
Postby iain cooper » Wed Oct 21, 2015 6:50 pm
probably referring to obscuring the front chassis legs ?
Postby OldSpice » Wed Oct 21, 2015 8:29 pm
I think it's a fair to middling chance you are spot on Ian. :wink:
Return to General Chat
