MK 2.5 oil filter
MK 2.5 oil filter
Postby Gordond » Wed Jul 08, 2015 1:42 pm
Can anyone please advise the easiest way to get at and change the oil filter on a 2004 MK 2.5 1.8i sports
Regards
Gordon
Gordond
Gordon Duncan
Re: MK 2.5 oil filter
Postby iain cooper » Wed Jul 08, 2015 6:26 pm
Take it to Eddie at Drumtochty Glen :lol:
Postby drumtochty » Wed Jul 08, 2015 10:48 pm
I hate Mk1, Mk2 and Mk2.5 oil filters but I do change then and complain as those that have visited can testify.
To be honest the Mk3 is still a bit of a pain to change and there is a thin copper pipe there to be broken if you are not careful!!!!!!!!!!!!!
Postby drumtochty » Wed Jul 08, 2015 11:04 pm
Even Mazda without telling anyone have two sizes of flutes on the end of the filter depending on the day they were made.
You can buy two cup wrenches or someone is makeing one that has both sizes of flutes on it and remove them with a 3/8 in ratchet that fits into hole in the cup wrench but during the last Tech Day in April. I sent one car away with the cup wrench still stuck to the filter as I could not get it off.
With a 2 post you can get to it but not see it from below and from the top it is just horrible to get at it.
There was a guy called Mark Swinhoe in the Grampian area who could get them off with his hand but I cannot do it.
I will check the flute size tommorrow for you.
Update http://www.amazon.co.uk/Laser-4990-65mm ... B00449CFK6
Where are you based.
Postby mgrays » Thu Jul 09, 2015 5:29 pm
I think it depends where the Mazda filter is sourced from .. US filters are bigger than Euro ones.. not sure about Japan ones. Lots of non Mazda suppliers probably get Japan source ones which are different from UK ones .. so likely bigger than Euro made ones! Look on the box to see where it was made.
It is tight but turn steering wheel to the left to make an opening behind the drivers wheel, lie on your back and while doing that thread your hand forward behind the driver' wheel .. and you can get to the oil filter. Sometimes you can get them off by hand if they have been put on "correctly" which is hand tight (swelling seal on contact to oil should hold them tight) but not all the time. I now turn until it is as tight as I can by hand and remove with a tool.. the cost of a slackening filter is too much to risk. The filter cup on 3/8" ratchet is the best way .. you may have to flip to "undo" on ratchet to get the cup off the filter.. before that I was using/still sometimes use the Draper fabric loop 1/2" filter gripper that rarely fails on any filter but needs to be wound up in place which is fiddly ;
http://www.amazon.co.uk/Draper-13771-2- ... B0001K9PF0
Tip is to put an old rag under the filter to catch the drips.. and pre fill the filter with oil before you fit it.
Coming in from on top is possible but need small hands and long arms! .. my muckle mitts have to do it in about 3 trips as I thread filter in, get tool in, get hands in (hand with tool cannot pass into gap) .. and still I get cuts from the petrol pipe clips.
Another way to make it easier is to remove drivers wheel and put car on axle stand on that side.. then at least you can see a bit more!
Postby Gordond » Thu Jul 09, 2015 7:35 pm
Thanks for the info. Looks as if it will keep me busy for some time.
Gordond
Gordon Duncan
Postby OldSpice » Fri Jul 10, 2015 9:53 am
iain cooper wrote:Take it to Eddie at Drumtochty Glen :lol:
Agreed. It's a lovely drive there I understand and you may even get a Castrol Syntrax 75/90 flavoured bacon butty chucked in. :lol:
Postby drumtochty » Fri Jul 10, 2015 12:23 pm
Usually Tuna I'm afraid.
Postby IanH » Fri Jul 10, 2015 12:30 pm
drumtochty wrote:Usually Tuna I'm afraid.
No :spam2: ?
Postby joeytalent » Fri Jul 10, 2015 2:26 pm
A pair of rubber gloves helps get a lot more purchase on it.
Postby drumtochty » Fri Jul 10, 2015 7:35 pm
There are always plenty rubber gloves in the garage Joey.
I go through a box every 6 weeks.
Postby joeytalent » Sun Jul 12, 2015 5:37 am
drumtochty wrote:There are always plenty rubber gloves in the garage Joey.
Out of interest, do you have a preferred supplier? I have stumpy fingers and struggle to find any that don't have a good 10mm excess for each finger.
