MK2 ECU
MK2 ECU
Postby rell_001 » Mon Jun 29, 2015 8:12 pm
Hi. New member.
(Edit: obviously I've put this post in the wrong place. Sorry. )
My MX5, 1.6, MK2, 2000 reg has been left out over winter.
Started and ran well for first 100 miles or so in May. Then conked out at traffic lights in ABZ.
Got it started again but misbehaves at idle and feels rough.
Following some reading of this forum I lifted the passenger carpet. I have a flooded passenger footwell and a badly corroded ECU coverplate.
Removed the plate and the ECU also shows signs of corrosion. Removed the connectors and discovered one pin has corroded and broken in the plug.
Removed the ECU. Its a B6ML.
I'm going to dry it out and I can probably get a jumper lead to replace the broken pin but this might not work.
Can anyone kindly suggest where I might source a working replacement ECU? Do I need to use exactly the same model number?
Do I need to also replace other parts (immobiliser, locks, keys etc) or will the old ones still work if I change the ECU?
Don't want to miss the Aberdeenshire summer :-)
Thanks in advance
R
rell_001
Re: MK2 ECU
Postby drumtochty » Mon Jun 29, 2015 9:00 pm
Yes it is a pain.
You need the ECU with the same number, the matching Lucas immobiliser box and the matching key.
So try and get the ecu repaired and get those cabin drains cleared.
Check the charging voltage if it starts as it may be up at 19 volts as the ECU on the Mk2 has the voltage regulator in it.
It should be nearer 14 to 15 volts.
If you are not up to spec on electrics etc and it starts bring it out to Drumtochty at the weekend if you want a second opinion.
PM me a phone number if you want to talk as this is not a change you realy want to make.
Re: MK2 ECU
Postby drumtochty » Mon Jun 29, 2015 9:29 pm
Re: MK2 ECU
Postby sclements » Mon Jun 29, 2015 10:23 pm
I have a B6MV ecu along with the immobiliser, inductor ring, ignition lock, door locks, boot lock and 2 keys - £100
However can't advise if it is a suitable alternative.
Scott
sclements
Re: MK2 ECU
Postby rell_001 » Tue Jun 30, 2015 7:31 am
Thanks for the prompt replies.
I'm going to try to fix the ECU first. Looks like I can jump the broken terminal.
Will post progress and may need more help.
R
rell_001
Re: MK2 ECU
Postby drumtochty » Tue Jun 30, 2015 8:01 am
Good luck!
Re: MK2 ECU
Postby rell_001 » Mon Jul 06, 2015 11:09 pm
Hi again
I cleaned the ECU up and soldered a lead to jump the broken pin.
The car is running well again. Very smooth and the idle is behaving properly also.
I have also cleaned out the drains so hopefully it won't happen again anytime soon.
Thanks for the advice.
R
rell_001
Re: MK2 ECU
Postby drumtochty » Tue Jul 07, 2015 8:00 pm
Have you also cleared the eight tiny sill drains one in front and to the rear of each jacking point front and rear.
They will hod water in the sill if not clear, this is over and above the drains behind the seatbelt towers
