puddle in the drivers side well
Postby neville1234567 » Wed May 28, 2014 3:38 pm
i have a mazda mx5 where did the water come from. just found out it has drainage holes can someone tell me where abouts please:
Re: puddle in the drivers side well
Postby drumtochty » Wed May 28, 2014 7:59 pm
What year is it and is it Mk1, 2 or 3.
Postby OldSpice » Wed May 28, 2014 8:01 pm
Iv'e found...over 6 decades...it normally comes from the sky under the label "Rain"...or Scottish airborne Spring water.
Try rubbing silicon grease into the door seals to swell them up and check for perishing/fit.
You will find two rear and two front openings under the sills. Poke summat in them like a wire coat hanger and clear them.
You'll likely have rust in there...just to cheer you up!
You don't want water near the passenger footwell by the way as it may travel to the ECU buried in there. If it gets damp or wet...your in trubs.
(Big Trubs) :shock:
