ICE ICE Baby - MK1 question
Postby Enjay » Thu Feb 01, 2007 5:47 pm
I have the so-called "Dixons" digital clock and cubby from the Mk2 in my Mk1. Personally I prefer digital clocks. I also have a BMW and the clock and cubby does look like it would be a pretty easy install. The illumination in BMWs is a reddish-orange so that will be out of harmony with most people's lighting. Don't know how easy it is to fix. I think BMW use orange perspex to get the light into the clock rather than orange bulb-condoms like Mazda use.
I'll try and post a pic of my cubby later. The lower slot on mine is larger than DIN and the radio/head unit was supported to a certain extent by the original cubby that was in place when I got the car. I cannibalised the cubby and fitted the new clock/cubby to it and then refitted the whole thing as a unit to ensure the hole was completely filled and the radio was properly supported.
Enjay
Postby Enjay » Thu Feb 01, 2007 10:23 pm
OK, not a great pic because it's dark in the garage ATM...
Enjay
Postby Markyboy » Fri Feb 02, 2007 10:17 am
Thanks for the photos guys. It gives me a great idea of how it will look when the job is done. The digi clock looks pretty good.
And the cubby looks big enough for the small packet of tissues I like to keep handy for when I'm brought near to tears if I see someone in a soft top with the hood up on a sunny day :P
Markyboy
Postby Gordon » Fri Feb 02, 2007 11:49 pm
The BMW clock has a plastic, red/orange coloured moulding over the bulb. Easy to remove and I coloured the bulb with a green felt tip. Looks OK to me, but I'm not that fussy.
Gordon
Postby Enjay » Fri Feb 02, 2007 11:54 pm
Coloured bulb condoms are easy to get, and cheap. I used dashlights_auto_bulbs on e-bay, but they are no longer registered. A few other e-bayers sell them though.
Enjay
Postby Wesly » Fri Mar 02, 2007 2:14 pm
got my new DVD player today for the car, will let you know how it sounds :)
Edit-... sounds pretty good for 100 quid! :)
Wesly
Postby jo » Fri Mar 02, 2007 6:04 pm
Mine has a blanking plate with the switch for the electric windows near the passanger side and a blanked off hole for a switch on the other.
jo
Postby Markyboy » Sat Mar 03, 2007 8:51 pm
So what is in the place where the window switches belong?
I'm not sure I follow what's been moved and why... :?
Markyboy
Postby jo » Sat Mar 03, 2007 8:57 pm
sorry ment to say electric mirrors not windows
jo
Postby Markyboy » Sat Mar 03, 2007 9:34 pm
Ah right. I didn't realise that you could get electric mirrors for a 5. It is a MK2?
Sorry - just looked at your avatar. Have you fitted them yourself?
Markyboy
Postby jo » Sat Mar 03, 2007 11:06 pm
No its a mark 1 and it came with them I think, well when I bought it they were on it.
jo
Postby Detritus » Sun Mar 04, 2007 8:59 pm
I saw this and thought it may be of interest.
http://cgi.ebay.co.uk/MAZDA-DIGITAL-CLO ... dZViewItem
Detritus
Postby mgrays » Tue Mar 06, 2007 7:49 pm
Made up a panel to fit clock and boost gauge with 323 electric window in the middle under stereo.. got the plastic from a sign maker which is easy enough to craft to shape. Needs to be 50mm gauges not 52mm (or 2") to fit... and a couple of wee switches and LEDs for the heated seats in the corners :wink:
Gauges came from Demon Tweaks but took 8 weeks to deliver and then I pulled them apart to create faces to match the OEM gauges!
.. and I do mean electric windows as I have no central console (Japan light weight carpet conversion).
Previous
