Postby moodindigo » Mon Feb 12, 2018 3:08 pm
The immobiliser light is on and the engine turns over but will not start. Can you disconnect the immobiliser? I have read that if the immobiliser is at fault you have to replace the ECU and immobiliser plus key switch etc as they are all paired together. Is this true
Would appreciate any assistance with this problem
Re: Immobiliser
Postby Rasc » Sat Feb 17, 2018 9:23 am
It would help if you also posted model and year, NA, NB, NC or ND?
Also you have posted in the new members section not the “I need help” area.. :)
MK1 RS Ltd, FM turbo, Motec ECU, Wilwood 4 pots, Tien coilovers, cusco rollbar, original BBS and Recaro's
MK2 RS, white, turbo, koni sports, in pieces right now..
