leak soft top
leak soft top
Postby looselips » Thu Jan 11, 2018 10:00 pm
hi newbie looking for help soft top leaking like the titanic where it meet at the back of the car ,any garage near me that can fix this, or is it a easy fix to do my self , dont like swimming pool in the boot of the car
looselips
Re: leak soft top
Postby drumtochty » Thu Jan 11, 2018 10:31 pm
The way the softop works is that the water runs down the hood into a plastic gutter you cannot see. The water then either comes out each end of the gutter behind the seatbelts and into a drain hole and that water is expeled from just behind the rear wheel but you have to be under the car to see the exit pipe.
Therefore we need to know what year the car is to help you further but it could be a cracked rain rail or just needing the drain tubes cleaned with a trombone brush.
Please also advise where you are based as some member may live nearby and can assist if you are lucky.
Trombone Brush
https://www.ebay.co.uk/itm/Trombone-Cle ... SwDApaVj-b
These also work on a MK1 or MK2
https://www.ebay.co.uk/p/Dapetz-24-600m ... 0005.m1851
