Seat belt warning bleeper.
Postby Fergie » Wed Aug 03, 2005 11:19 am
Does anyone know how to disable this damned thing on a 2.5? I always use the safety belt, but unbuckle when reversing, which causes an increasingly frantic bleep that is truly annoying.
Fergie
Postby Phil » Wed Aug 03, 2005 11:57 am
I believe that if you look under the seat you will find a plug/socket which if you disconnect will stop the bleeper. Have a look on the National forum for more info. :)
Phil Mitchell
