Rattling suspension
Rattling suspension
Postby ralphie » Tue Jul 12, 2005 2:00 pm
Hi new member here. :lol: I have a 1990 mk1. everthing is great apart from a metalic rattle from the rear suspension, only when going over rough ground, new konis have been fitted, springs all Ok... Any ideas?????
ralphie
Postby Greg & Nic » Tue Jul 12, 2005 2:20 pm
Just one suggestion -
A lot of aftermarket rear brake pads come without the little M shaped anti rattle springs that are supplied with OEM pads. If the rear pads are fitted without these springs then they can move about a little in the calipers. Although it doesn't affect the brake safety or performance it can cause a metallic rattling when driving along. Removing the pads, cleaning up and refitting with a film of copper grease usually cures it but in time it will come back.
91 BRG V Spec....The Wee Beastie
Greg & Nic
Postby ralphie » Thu Jul 14, 2005 1:39 pm
Thanks, I'll give it a try.... if not I've been told possible the suspension mounts.. ( rubber gasket )...... cheers
ralphie
Postby ralphie » Thu Jul 28, 2005 4:58 pm
Thanks guys was the brakes well spotted
ralphie
