1.8 mk1 suspension
1.8 mk1 suspension
Postby Azz Kiker » Tue Jun 28, 2005 7:22 am
Having a few problems with the front suspension on my 5. the driver side spring is on its way out and im starting to worry. would it be best to replace both sides at the same time? does anyone know where i can find 45mm lowering springs... im sure its been dropped that but not sure.
Purple Pocket Rocket... sounds rude. The car i meant :wink:
Azz Kiker
Postby Phil » Tue Jun 28, 2005 8:17 am
It is always recommended to replace shock absorbers or springs in pairs as even if the other side looks ok it will have worn or relaxed compared to a new one. :?
Phil
Mk3, 2ltr, Brilliant Black, Option pack, Air Con, Eibach springs, Member No. 45**
Phil
Phil Mitchell
Postby Azz Kiker » Tue Jun 28, 2005 7:29 pm
the shop im going to get them only sells them in sets of 4... should i just go ahead and replace the whole suspension or would that just be silly as the back is fine.
Azz Kiker
Postby Richardn » Tue Jun 28, 2005 7:31 pm
Depends if you think they will match what is on
Richardn
