Burning oil smell after driving
Postby secat187 » Tue Feb 22, 2005 2:15 pm
Has anyone else noticed a smell of burning oil possibly coming from the back axle?
I noticed it on my old 1.6 mx5 and now on my 1.8. Is it another 'feature' of the car. I dont seem to be dripping oil from anywhere.
any Ideas?
secat187
Postby mgrays » Tue Feb 22, 2005 6:28 pm
More likely the CAS O ring .. this is the timing pickup at the back of the engine (changed sides from 1.6 to 1.8 - the side where the ignition leads do not go is where the CAS is). This O ring dies after 8 years or so .. and then the oil can drip down on the exhaust manifold on a 1.8.. but normally it just covers the front bellhousing of the gearbox.
Otherwise.. not sure it is just you smelling diesel cars with the roof down .. first time you follow one you really notice it.
Postby secat187 » Tue Feb 22, 2005 6:38 pm
Cheers, I'll have a look when I get round to servicing it.
secat187
Postby Si » Tue Feb 22, 2005 7:24 pm
mgrays wrote:More likely the CAS O ring .. this is the timing pickup at the back of the engine (changed sides from 1.6 to 1.8 - the side where the ignition leads do not go is where the CAS is). This O ring dies after 8 years or so .. and then the oil can drip down on the exhaust manifold on a 1.8.. but normally it just covers the front bellhousing of the gearbox.
That's EXACTLY the symptoms of mine. Is it an easy job to replace, or should I just take it to the garage?
Brilliant info as usual Malcolm :)
Si
Si
Postby Si » Tue Feb 22, 2005 7:25 pm
P.S. sorry for the thread hi-jack :oops:
Si
Postby secat187 » Wed Feb 23, 2005 12:42 am
It's ok.
secat187
Postby Richardn » Wed Feb 23, 2005 9:01 am
Full instructions in the usual place :D
http://www.miata.net/garage/cas_oring.html
