Fuel Tank Questions
Fuel Tank Questions
Postby lochpark » Mon Feb 21, 2005 10:36 pm
Two questions regarding the fuel tanks on Roadsters
Does anyone know if its possible to get an adapter / kit to reduce the filler neck in the Roadster so that it will only accept the unleaded nozzle ?
Is it possible to fit an anti syphon device into the filler neck ?
Shaun
lochpark
Postby mgrays » Tue Feb 22, 2005 6:24 pm
http://www.sftmx5parts.co.uk/
Under Fuel they show a universal unleaded adapter for SVA
http://www.kayuautos.com/service.htm
near the bottom another or same restrictor
http://www.spmotor.co.uk/fuelfiller.htm
better picture of same thing
http://www.importsolutions.co.uk/fuel_neck.asp
nicer custom ones in plastic but pricer no doubt
as for anti-syphon .. well a locked lid normally deters most.
Postby lochpark » Wed Feb 23, 2005 12:11 pm
Cheers mgrays, I'll check these links out.
Shaun
lochpark
