Cat emission passes
Cat emission passes
Postby Robin » Wed Oct 03, 2007 1:35 pm
Already listed in Central Scotland Garages section.
"David Graham will do a cambelt, water pump etc + full service with correct oils for £340.00 all in, including parts. Has done many 5's, knows their little foibles. Basic deal assuming no other horrors are discovered..in which case you would be informed before remedial work undertaken.
You supply the cambelt kit which includes rollers, spring, and gasket, £300.00 instead. Water pump is optional but highy advised.
Any other work no problem at very competitive rates.
Extremely helpful & honest chap & staff.
5 Tamfourhill Avenue
Camelon
Falkirk
FK1 4RT
Tel/fax 01324 621222
Mobile 07743 668035"
Reason for post.
David has the MOT emissions database of 94 & previous imports which either need the cat off, or already do have it removed, to ensure within the required levels, a Pass
Which is....handy to know :wink:
Give him a call prior to doing anything along those lines...he is happy to advise about things as far as he is concerned.
Robin
