Fitting a Hard top
Fitting a Hard top
Postby secat187 » Fri Jan 21, 2005 3:41 pm
I've got a 94 eunos and I would like to know what I need to fit a hard top to my car. I think I may need a fitting kit, but having never seriously looked at hard tops I am at a loss.
secat187
Postby Richardn » Fri Jan 21, 2005 3:48 pm
and
2 No Required
all available from
http://www.sftmx5parts.co.uk/hood_hardtop.htm
Postby secat187 » Fri Jan 21, 2005 4:09 pm
Ok I understand the mushroom bolts, but the side brackets are confusing me a little. Where do they attach on to the car?
Please excuse my ignorance on this.
secat187
Postby graeme » Fri Jan 21, 2005 8:27 pm
They go immediately behind the door (by your shoulder). A bit of drilling is needed.
graeme
Postby lochpark » Sat Jan 22, 2005 12:04 am
I too have a Eunos and have been contemplating fitting a kit (just in case) and I've been watching some on good old ebay, some have plastic panels along with the parts decribed above.
If I get only the parts listed above, how easy is it to "cut" the plastic panels ?
lochpark
Postby pablo » Sat Jan 22, 2005 12:43 am
Lochpark, I've got a Eunos with hardtop fitted.
I work in Ayr so if you want to come and have a look at how it all fits together some day, feel free.
pablo
Postby lochpark » Sat Jan 22, 2005 1:01 am
Pablo, thanks for the offer, I'll take you up on that.
Shaun
lochpark
Postby Richardn » Tue Jan 25, 2005 7:46 pm
lochpark wrote:I too have a Eunos and have been contemplating fitting a kit (just in case) and I've been watching some on good old ebay, some have plastic panels along with the parts decribed above.
Easy, if you take them off the area to cut out is marked
Postby secat187 » Mon Feb 07, 2005 5:53 pm
Hard top is coming tomorrow :D
I've already got the fitting kit, the two mushroom bolts and the 2 side brackets, but I'm not exactly sure how the brackets will bolt on. I'm pretty sure I'll be able to how out where the line up, but do I have to make a threaded hole for the bolts?
##edit##
Just been told that there should already be two threaded holes behind the trim. Just need to find them and cut the trim to fit around the brackets.
secat187
