a couple of niggles
a couple of niggles
Postby neroangelo » Sat Nov 20, 2004 4:55 pm
hi guys,
I have a couple of niggles....one is that there is a rumbling developed from the rear of my '93 Enos Roadster, it doesnt change with clutching or speed, thought it may be the wheel bearings or Drive shaft...any ideas?
Secondly...there is a faint 'whining' appeared from the front end, it is louder if the car is doing 60-70 mph....but it is there constantly after the engine is warm after about 30miles, doesnt change if engine off or clutched.....I had the cam belt,pulleys and tensioner and the Ac/PS belts replaced about 6 weeks ago.....has anyone else experienced this?
Any advice would be gratefully recieved
thanks Scott
neroangelo
Postby Richardn » Sun Nov 21, 2004 8:58 am
Wheel bearings usually chance noise in corners as the load on it varies
