drain pipes
drain pipes
Postby rockdoc » Tue Nov 09, 2004 1:00 pm
hi, i have a 91 eunos and would like to check/clear the drain pipes/hose that carries away the excess water from the roof- i,ve read they are in front of the rear wheels- for the life of me i cannot see them, that goes for the "slits" in the sills also.
anyone help?
rockdoc
Postby Si » Tue Nov 09, 2004 2:07 pm
From the top, if you put the hood in to a half open/closed position and look between the top of the seat belt pillar and the edge of the bodywork. It's quite tight in there, but just where the hood frame folds down (if it were folded all the way down) you should be able to feel a hole about 1.25" in diammeter.
Richard will probably explain how to find them better :)
Postby kristoff » Tue Nov 09, 2004 5:41 pm
Rockdoc,
Try the link below for some good info. You will find other links on this page that will pretty much conclusively answer your questions.
http://www.mx5ocforum.co.uk/viewtopic.php?t=11475
Chris
Gerr on t'internet.
kristoff
drain holes
Postby rockdoc » Tue Nov 09, 2004 7:45 pm
thanks- found them ,job done, now to change out aircon pump!!
rockdoc
