Plastic bumper repairs
Postby grouse » Mon Oct 11, 2004 4:37 pm
Need to know if dents etc can be removed from plastic bumpers?
Not the painted ones that the "5" has - the grey/black insert type.
Any info available on "Trimtech" (Stirling area I believe)?
Thanks.
Grouse
Another fine example of
"low-flying technology!"
grouse
Postby Hardtrack » Mon Oct 11, 2004 10:19 pm
Yes they can,just the same as body work only you spray it with bumper/trim paint,which will come in the same colour as your grey or black bumper.................it's similar to the fine stonechip type paint you get from halfrauds for bumpers,only that is crap :? ,pure thinners with a cheap plastasizer paint :? .Most decent coachworks will be able to repair your bumper whether it be cracked(plastic welded) or dented.I could give you a number if your stuck,but it is in Ayrshire.I sprayed a grey trim panel on my 626's bumper with the proper stuff and you could not tell the difference..........so as said before,yes a dent can be repaired :)
95 G-Ltd 1.8
Hardtrack
Postby grouse » Tue Oct 12, 2004 7:00 am
That's good news - thanks! :D
I've since made a couple of (hopefully) useful contacts, so we'll soon know for sure... :)
Grouse
grouse
