oil pressure
Postby Phil » Tue Sep 21, 2004 10:53 am
As far as I am aware the oil pressure gauge on this model is a 'proper' gauge giving relatively accurate readings (later models had what is best described as an on/off switch feeding the gauge). :?
When you say between 2 and 3 I am assuming that this is Bars, which in real money is approx. 28 to 42 psi. :D
With the engine warm and is idling (800 rpm) the pressure on my car is the equivilent of 2 bar, at speed, the pressure goes up to just below 60psi which would be 3.5 bar on your car. This is quite normal, the pump is running faster, the engine is working harder. 8)
When the engine is cold you will find that the pressure is higher due to the oil being thicker (viscosity), the pressure reduces as the engine, and the oil, warms up :o
If you imagine that oil pressure is like blood pressure in a human, pressure and pulse rate goes up and down depending on what you are doing. :shock:
To sum up I think that your engine is working fine and all is well. :D
Phil Mitchell
Postby Richardn » Tue Sep 21, 2004 3:56 pm
Your cam cover gasket is leaking into the plug holes
Postby BillB » Tue Sep 21, 2004 8:54 pm
I agree with Richard, your gasket is leaking and allowing oil into the cylinders. Have this checked out ASAP.
When someone gives you a pat on the back make damned sure they did not have a knife in their hand.
BillB
Postby Si » Tue Sep 21, 2004 9:19 pm
Hmmm.... would that also explain my fluctuating pressure gauge when at idle?
Postby Hardtrack » Tue Sep 21, 2004 11:53 pm
No...........have you had the car checked out properly,if your putting in a half a litre of oiland no leaks....it's burning it.......but if two of your plugs are covered in oil and as you posted there is no oil leak and your loosing pressure.only says one thing to me :(
95 G-Ltd 1.8
Hardtrack
Postby Richardn » Wed Sep 22, 2004 10:22 am
No...It's the Cam cover Gasket
Postby Hardtrack » Wed Sep 22, 2004 5:11 pm
I know you are very knowledgable on mx5's Richard,but could you maybe elaborate a little......as your answer is very brief? :)
95 G-Ltd 1.8
Hardtrack
Postby Richardn » Wed Sep 22, 2004 9:12 pm
Ok this link will tell you how to do it :)
http://www.miata.net/garage/valvecover/index.html
(and you will see how much I could post :? )
Oil Pressure
Postby bryanc » Thu Sep 23, 2004 3:02 pm
Richard, http://www.miata.net/garage/valvecover/index.html :D Excellent
Know any more before I go buy the workshop manual.
bryanc
STUCK ?
Postby loftladderman » Tue Oct 12, 2004 6:59 am
IF you are stuck on the gasket ????
I have 2 new rocker cover gaskets as spares (just in case...LOL) IF you are stuck and also the facilities here in St Cyrus to do a fast change over for you if you so wish ?
10 minute job is all :-)
Depends WHERE you reside I guess.
I am here till this Thursday evening, and away playing in the Greddy until a week on Wed / Thur.
Me the Greddy and the DUG are off to France camping !
Can reach me fast by telephone on 07973 671 103 (Loft Ladders Line)
Regards from Mack
Greddy Turbo :-)
www.macksmx5s.com
www.loftladderman.com
loftladderman
