License plate light?
Postby ColinB » Mon Mar 14, 2016 1:11 pm
MOT is booked on Wednesday so some checks undertaken this morning. The off side license plate light is not working. I've tested the bulb and it's working. I'm guessing a broken wire or loose connection. I have traced the wire back until it merges with the main loom in the boot. And it all looks fine. Is this a common fault and is there a quick easy cheap fix.
Mk 2.5 1600 Euphonic
Thanks in advance
Colin Bell
Re: License plate light?
Postby gm » Mon Mar 14, 2016 2:08 pm
To get through the test, I would splice a wire off the side that is working, then trace the problem at your leisure.
