Stubby Aerial Mk1
Stubby Aerial Mk1
Postby drumtochty » Sat Dec 26, 2015 9:37 pm
The car has an electrical aerial at the moment that does not work and the owner wants one of those stubby aerials rather than the electric one fixed.
I got a manual aerial base to put in place of the electric base and an ebay stubby.
The ebay stubby comes with two threaded adapters one is too large a diameter, the other with the stubby has the large diameter end to fit the stubby and a smaller diameter part on the other end to fit into the aerial base that is not long enough to catch the threaded receptor in the manual base.
Apart from buying the mx5parts expensive adapter has anyone any else found a solution.
Re: Stubby Aerial Mk1
Postby sarahlc » Sun Dec 27, 2015 12:18 am
I have the MX5parts one I'm sorry to say :?
sarahlc
Sarah Close
Postby drumtochty » Sun Dec 27, 2015 12:43 am
I think I should have ordered that at the same time!!!!!!!!!!!!!!
I think you made the correct decision Sarah.
