MX5 Mk4 Underside
Re: MX5 Mk4 Underside
Postby liathach » Sun Nov 01, 2015 9:51 pm
Good to see you are still around Chiefy!
I now have an SLK but still go out on MX5 runs as I am still a member of the OC. I run as tail end Charlie (which I prefer) and the red SLK is easily seen beyond all the grey 5s.
Postby drumtochty » Sun Nov 01, 2015 10:35 pm
Welcome back Chiefy.
I had my 2009 impreza on the lift today.
While I would give the Mk4 MX5, 7 out of 10 for underside exposed area coverage and all the areas under wheel arch protectors are bare.
The Impreza is better protected re exposed areas 8.5 out of 10, it still has bare areas and like the MX5 Mk4, the area under the wheel arch protectors I checked were bare.
Previous
