MX5 Blonde Now A Mazda Mender
Postby drumtochty » Sat Sep 12, 2015 8:28 pm
In February this year Donna posted under the user name MX5 blonde about her Mk1 cutting out, it was both a wet ECU and an Error 9 which replacing the rear temperature sensor sorted.
Recently her Mk1 had an oil leak and she wanted to do some rust proffing so last week we did some rust proofing and I decided that it was the cam sensor O Ring that was leaking.
Ordered the O Ring and fitted it today.
Well the O Ring was fine it was the cam cover gasket leaking but it is a pig to get the cam sensor housing back on.
I decided lunch was calling before we got into that problem.
For the usual suspects it was banana rolls and agave nectar, aye that's was a new one on me as well but Donna though it was good.
Well Donna got out to the garage first after lunch and had the CAS housing fitted before I could get in the garage and then put the cam cover and the coil pack back on the car on her own.
At that point I gave here full instructions on using the 2 post on her own and advised her she was now a Mazda Mender.
Well Done Donna.
Re: MX5 Blonde Now A Mazda Mender
Postby Mx5 blonde » Sat Sep 12, 2015 8:40 pm
:D Thanks Eddie for your help and now being a Mazda Mender very chuffed !!
Mx5 blonde
Users browsing this forum: Majestic-12 [Bot] and 1 guest
