Hardtop HRW.
Hardtop HRW.
Postby BBAV » Fri Jun 26, 2015 5:48 pm
Hi All,
I have very recently bought a MX 5 1999 10th Anniversary Ltd. Ed. It came with a hardtop with a heated rear window (well I thought it had) but what the seller didn't point out to me at the time and I didn't notice, was that the power connector clip on the glass was broken off. Anybody had any experience of this, do you know if it is just a matter of soldering a new clip back on, or is it a bit more technical than that like some kind of special soldering required or have I hit bad luck already, and means the glass needs replacing??
Regards,
BB.
BBAV
Re: Hardtop HRW.
Postby gm » Fri Jun 26, 2015 5:52 pm
a similar problem was discussed here, not sure what the outcome was though ?
http://www.mx5scotland.co.uk/board/viewtopic.php?f=7&t=13765
Re: Hardtop HRW.
Postby DTB » Fri Jun 26, 2015 6:15 pm
A decent autoelectrician should be able to sort that for you easily enough for hardly any £'s.
DTB
Re: Hardtop HRW.
Postby BBAV » Fri Jun 26, 2015 7:15 pm
Thanks, gm & DTB
Will keep you posted how I get on with it and what the outcome is, which hopefully will help anyone in future if they get the same problem.
BB.
BBAV
