cooling issues
cooling issues
Postby paul » Mon May 25, 2015 6:16 pm
hi , having some issues with the temp gauge , just done the cam belt & water pump and thermostat housing , think i have all air out system and all seems good until i go over 70 mph then the gauge rises up to 3/4 when i slow down again after a few seconds the temp comes back down . thought i might have installed the thermostat wrong so i removed it , bled system again ........ same again . any thoughts anyone ??? its a mk1 1.8 , 1996 merlot . new cap has been fitted and no signs of leakage from any where thanks in advance
paul
Re: cooling issues
Postby drumtochty » Mon May 25, 2015 8:36 pm
Typical of a radiator that is blocking, that age is a good age for the radiator.
Sorry for the bad news. Otherwise is there any lack of performance or rough running.
Re: cooling issues
Postby paul » Mon May 25, 2015 9:13 pm
its running beautiful , no leaks or boiling sounds when stopped , tank working as it should , after i rebuilt her i filled with water to check for leaks .... all good . drained her down and got the hose in there , water ran clear after a short time , buttoned everything up and all is good except at 70 plus . runs really nice everywhere just this wee niggle . the rad looks new ish .... would a holts flush be of any use ?? Thanks for your input eddie . much appreciated . paul
paul
Re: cooling issues
Postby drumtochty » Mon May 25, 2015 10:10 pm
Try a flush but the opinion is that due to very small diameter tubes om the MX5 core when they block they block.
Re: cooling issues
Postby paul » Mon May 25, 2015 10:18 pm
think you are spot on eddie , as per usual , rad ordered , do you think the under tray makes a difference
paul
Re: cooling issues
Postby drumtochty » Tue May 26, 2015 9:20 am
Yes it improves cooling as it routes the air the correct way under the engine.
Re: cooling issues
Postby gm » Tue May 26, 2015 11:53 am
If you haven't already ordered a new radiator, I have a brand new one in the attic that I bought when I thought mine was leaking (it was just steaming from over spilled coolant)
Re: cooling issues
Postby paul » Tue May 26, 2015 5:59 pm
ah .... i ordered it last night thanks anyway . Paul
paul
Re: cooling issues
Postby paul » Wed May 27, 2015 5:38 pm
ok , job done and sitting pretty - thanks eddie ,
paul
Re: cooling issues
Postby drumtochty » Wed May 27, 2015 7:10 pm
Your welcome!
