Oil question for MK3
Postby L9XSS » Tue May 19, 2015 8:16 pm
I'm sure it's been asked before but was looking for some informed advice. Higher mileage MK3 (90,000 miles on an 06 plate).
What grade of oil should I be using? I'm aware of a few cars running very low on oil and causing big end failures/knocking engines. Want to keep my 1.8 in tip top condition and wanted your thoughts on brand and grade etc at this mileage?
Many thanks.
L9XSS
Re: Oil question for MK3
Postby drumtochty » Wed May 20, 2015 7:19 am
The link below takes you to a used oil analysis of a 120,000 mile MK3, you will have to log in to Miata.net to read the UOA.
It is just a perfect report, if you do not speak UOA.
In the states Mazda spec 5W/20 and this is what this car was using.
In the UK as there was no availability of XW/20 oils, Mazda spec, a 5W/30 A5/B5 oil. There is no reason what so ever not to use the UK spec recommendation.
The car takes 4.5 litres, therefore that makes Castrol a non runner as they sell in 4 litre tubs so you would need an expensive 1 litre bottle as well.
So buy any 5W/30 A5/B5 oil, if you want to waste your money go to Opie Oils and buy one of their £50 pots of oil. Otherwise go to Halfords or your local motor factor and buy the cheapest 5W/30 A5/B5 and a filter
Also 3 litres of 75W/90 gear oil spec GL5 that will do both the gearbox and the diff as it is a 1.8 different for a 6 speed 2 litre Mk3.
1.5 litres of brake fluid as that will not have been changed in a while.
When were the plugs and air filter last .
Postby L9XSS » Wed May 20, 2015 8:17 am
Eddie, fantastic post, very informative, thanks. Didnt think about the gearbox oil too, but thats a great shout. Not sure about the brake fluid and spark plugs, will trawl thru. The service history and speak with the previous owner in detail.
Many thanks.
L9XSS
Postby drumtochty » Wed May 20, 2015 9:14 am
this is a used oil analysis of a 180k mile car and it is perfect.
http://forum.miata.net/vb/showthread.php?t=442055
Postby Scott_J » Sat Aug 22, 2015 8:24 am
Halford are selling the correct grade (Ford) Mobil 2000 fully synth 5w/30 for £23, 5 litres. Just changed my oil & filter last week.
Scott_J
