MK 3.5 Heater Issue
MK 3.5 Heater Issue
Postby special k » Fri Apr 17, 2015 3:33 pm
Afternoon All
My boss has a MK3.5 (2009) 2.0 sportech and he mentioned to me today that he seems to have an issue with the heater. He has had it for a few months with no issues however he has noticed recently that heater when turned to a mid temp range blows lukewarm air. When turned to full heat it still blows lukewarm air which is strange as it was fine before. I wondered if there was anyone out there that has encountered this problem or could assist & perhaps advise of a possible solution
Regards
special k
Steven Kilpatrick
Re: MK 3.5 Heater Issue
Postby drumtochty » Fri Apr 17, 2015 3:40 pm
First job is to check there is plenty fluid in the radiator.
The temperature guage in these cars is just a toy so they do not give accurate readings.
Postby IanH » Fri Apr 17, 2015 6:18 pm
Postby special k » Fri Apr 17, 2015 9:14 pm
Eddie many thanks. Coolant level checked and is fine
Ian many thanks for the thread regards similar issues stateside. Will pass the info on
Regards
special k
Steven Kilpatrick
Users browsing this forum: Google [Bot] and 6 guests
