bleed nipples
bleed nipples
Postby hold on tight » Sat Apr 11, 2015 6:05 pm
Quite impressed that I managed to get the bleed nipples out of the front calipers this afternoon. I don't think anybody has been near them in many years. I couldn't quite work out what thread they are, to replace them; - they seemed to be something between an M6 and an M7, - they're not some daft imperial size, are they?
hold on tight
Re: bleed nipples
Postby drumtochty » Sat Apr 11, 2015 6:13 pm
No they are metric if you go on to
http://www.speedbleeder.com/size.htm
and some of the other pages on the site you will get the size there you also have to look at the tread pitch not just the diameter.
Re: bleed nipples
Postby hold on tight » Sat Apr 11, 2015 9:05 pm
It appears they are different threads front to rear. M8 x 1.0 front and M7 x 1.0 rear. Now that's handy!!!!!
Anyway, I've ordered this kit;
http://www.ebay.co.uk/itm/261633671224?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I'll be replacing all four when they arrive, since they were in a bit of a state due to lack of attention by previous owners, and the fact that these cars sure know how to RUST!
At least the nipples came out, albeit with a blow torch and a lot of WD40, which is a pleasant change when you're used to working on Peugeots with their aluminum calipers and steel nipples; - once those bad boys seize, they are NOT coming out!
hold on tight
Re: bleed nipples
Postby drumtochty » Sun Apr 12, 2015 10:46 am
Welcome to MX5 bleed nipples.
The front on a Mk 1 or 2 are M8 diameter 1mm thread pitch with a length of 35.5mm
The standard 8mm bleed nipple is M8 x 1.25mm pitch x 28mm long so the standard nipple will not fit an Mk1 or 2 front.
The rear is standard.
The Mk1 and 2 use M7 x1mm pitch with a standard length.
The Mk3 has the same non standard front but the rear is standard with a slight length reduction.
So just different enough not to be able to buy the front nipples from a local motor factor.
Re: bleed nipples
Postby hold on tight » Tue Apr 14, 2015 7:58 pm
Perfect! Six quid on ebay.
All fitted, brakes bled, and refilled with DOT5 fluid.
I think the car deserves a wee run on the East Fortune outing, now.
hold on tight
Re: bleed nipples
Postby drumtochty » Tue Apr 14, 2015 9:33 pm
Great company they do lots of small brake bits for specific cars in kits
