water ingress passenger footwell
Postby iain cooper » Sat Apr 11, 2015 4:44 pm
water is coming in to the passenger footwell.
it is dripping from above the fuse box somewhere and landing on the floormat. (2013 RC graphite )
any ideas where it is coming from?
Re: water ingress passenger footwell
Postby IanH » Sat Apr 11, 2015 6:05 pm
Postby JimF » Sat Apr 11, 2015 6:11 pm
Had the same leak and replaced both scuttle grommets. Parts from MX5 Parts. http://www.mx5parts.co.uk/windscreen-co ... -3199.html. I also bought 2 of the plastic screw covers as it is easy to break them while removing.
JimF
Jim Ford
Postby IanN » Sat Apr 11, 2015 8:40 pm
Probably skittle grommets as stated but as it's still under warranty I'd take it back to the dealer and complain.
2016 Mk4 Icon Special Edition
IanN
Ian Ness
Postby iain cooper » Sat Apr 11, 2015 8:41 pm
thanks guys, I wouldn't have thought this would happen on an 18 month old car, but going through the links/posts there are indeed newer models with this problem.
I know I should really take it back to the dealer to be sorted but am tempted to have a look myself.
any further tips on the fix ?
ps how are the scuttle grommets held into the rectangular holes ? ie what stops them being pulled out when the screw is tightened ?
Postby JimF » Sat Apr 11, 2015 9:34 pm
Our car was around 6 years old when I replaced the grommets. The foam at the base had disintragated thus letting water in. If you look at the pictures of the grommet on the MX5 website you can see clips at the sides, these hold them in place.
JimF
Jim Ford
Postby liathach » Sat Apr 11, 2015 10:05 pm
I took mine off, cleaned the area with white spirit and replaced them using loads of sealant - did the trick! I find it surprising they do deteriorate since there is no movement in that area to cause problems.
Liathach
liathach
Malcolm Lamont
Postby iain cooper » Sun Apr 12, 2015 9:27 am
thanks again, I was going to have a look today, but the heavens have opened here in the west !!
