2015 Drumtochty Tech Day Full
Postby drumtochty » Wed Apr 01, 2015 10:19 am
Dave
9:00 Mk3, 6 speed
Engine ,Gearbox and Diff oil change, under car security check, touch up underseal.
Ferg
Stewart Mk3, 6 speed
Engine oil and filter change, under car security check.
Lorraine Mk3.75
Flip exhaust if not done before tech day.
Larry and Mel Mk3 6 speed
Under car security check plus oil changes
TJ Mk2
Under car security check if not done at a previous time.
Alistair
Service, underside security check and survey for future rustproofing.
Helen B
Look underside and security check.
Gordon
Oil and filter change and Exhaust check.
Interior stuff off the ramp
As I'm now not attending work, if anyone wants a more relaxed look at their car on the ramp, PM me and we can do that on a one to one basis at a date that suits us both.
No need to bring any tools as the Drumtochty Facilities are fully equiped.
Catering
Joan will have tea and coffee available all day as well as bacon rolls in the morning, soup and filled rolls around lunch time and scones for everyone apart from TJ and myself as we are just too fat. Lunch will be more of a rolling event as some people will be busy with their car at times while others are free to eat.
Please add to this listing
Re: 2015 Drumtochty Tech Day Rolling Work List
Postby IanH » Wed Apr 01, 2015 11:25 am
No work needed, will bring a camera and come along for the Craic as they say :lol:
Postby liathach » Wed Apr 01, 2015 1:57 pm
Same as Ian although if anyone knows how to dismantle the SLK to access the rear of the Comand system to fit a lead from a rear camera, do let me know!
Postby OldSpice » Wed Apr 01, 2015 2:33 pm
Which flavour of tuna sarnie is it to be?
A cheeky hint of DOT 4?
An excellent year of Copaslip from the south of the garage?
Postby drumtochty » Wed Apr 01, 2015 5:31 pm
The syntrans usually comes from the nearly well washed hands when I do the lunch.
The better half is looking after the catering this time so I assume a quality increase in the offering.
Postby CaptainNorth » Wed Apr 01, 2015 7:40 pm
Sounds great Eddie! :D Thanks.
If we could squeeze in an engine oil change to the 09:00 slot that would be ace - but no worries if not enough time.
Dave
NC1 BBR Super 200
CaptainNorth
Postby drumtochty » Wed Apr 01, 2015 8:10 pm
Not a problem as it will be on the ramp anyway.
Postby tjay » Wed Apr 01, 2015 10:39 pm
Awe come on Eddie, here's me being good too, Lost 12 lbs over last 8 weeks !! Was out for a run with the Taysiders on Sunday and only had a coffee and a protein bar !!! so speak for yourself !! :D :D :lol: :lol:
btw we will bring some gluten free rolls or bread for Jen on the day.
cheers
ps would like g/box and engine oil and filter done if poss as we are going down to the Spring Rally. Might try to come up either Monday or Wednesday if you are available, this would free up time/space for the Sat/sunday ??? Will give you a call tomorrow.
tjay
tom + Jen mcginnis
Postby drumtochty » Wed Apr 01, 2015 10:47 pm
See you next week Tom.
I have oil and filters here.
Postby BoabG » Thu Apr 02, 2015 4:19 pm
Might pop up and see you if that's OK?. Especially now that i have another make of convertible 8)
Bob.
BoabG
Bob Gray
Postby drumtochty » Thu Apr 02, 2015 5:33 pm
Your welcome Bob at any time.
Postby BoabG » Thu Apr 02, 2015 7:04 pm
Cheers Eddie.
BoabG
Bob Gray
Postby mgrays » Fri Apr 03, 2015 1:15 pm
liathach wrote:Same as Ian although if anyone knows how to dismantle the SLK to access the rear of the Comand system to fit a lead from a rear camera, do let me know!
Malcolm,
Keep meaning to buy MB STAR software as I need to reprogram my fuel gauge on the ML500..
I have had the Command unit out from that car.. bought the special tool as on a 2002 Command 2.0 it has 2 slots either side (tried to cut parts to suit) as shown. Not sure you want yours that far apart? Mine needs a TV tuner adapter to take a standard RGB PAL reversing camera which is silly money- £250 .. not sure if you do?
Not sure what day this is on .. doubtful I will get down but Eddie knows where I am.
.. and to give it MX-5 relevance .. here is that unit fitted to an MX-5 :-) http://www.mercupgrades.com/COMAND+Retrofit-article-1.html
Postby liathach » Sat Apr 04, 2015 9:29 pm
Cheers for that MAlcolm. I have found some info online and it seems I might have to dismantle the central glovebox etc!
Re: 2015 Drumtochty Tech Day Full
Postby drumtochty » Mon Apr 06, 2015 3:21 pm
We have now reached the reasonable maximium number of cars to get on the ramp and have reasonable time to do the work concerned or to generally to inspect and titavate.
Postby IanH » Mon Apr 06, 2015 3:56 pm
Is the first post in this thread the rough running order?
I'll come down with Lorraine to have one less car cluttering up the drive.. :D
We'll probably target back of 10.
Postby drumtochty » Mon Apr 06, 2015 5:14 pm
Some locals early and the rest on a when posted basis but if people like HelenB are only wanting a look and we may find something that is needing a quick tighten then I intend to let some of those cars on the ramp between three oil change jobs.
Bit of a see who arrives and when.
Postby drumtochty » Wed Apr 08, 2015 9:55 am
Directions removed
Postby Muntedog » Wed Apr 08, 2015 2:31 pm
Thanks Eddie i'll send out a smoke signal if I get lost.
My car's a MK1 by the way.
Cheer's Ferg.
Muntedog
Fergus Haggart
Postby tjay » Wed Apr 08, 2015 8:30 pm
As Eddie and I were both free today I took my Mk2 up to him today, he very kindly checked the underside, changed engine oil and filter, changed diff and gear box oils too, I had a spare set of new spark plugs so changed them too.
Also made Jen and I a cuppa and when Joan came back from visiting her mum we had another cuppa and a roll too.
Had a lovely top down drive there and back in the sunshine, all in all a very nice afternoon and bonus is that we freed up another slot for Saturday for others.
Many thanks to Eddie for the work done on my car and we are both looking forward to Joan's home made soup and bacon rolls on Sat morning.
I will go to the bakers en route to you for some cake "treats"
btw car feels like it is pulling better through the gears and engine far quitter with the new oil in it. sorted !!!
cheers
:D :D :D
ps left a brand new set of Iridium spark plugs to suit either a Mk3 or 3.5 if anyone interested see either Eddie or I on Sat.
tjay
tom + Jen mcginnis
