Clutch Issue
Clutch Issue
Postby Dan_Mosca » Tue Mar 03, 2015 5:31 pm
Last month I had to replace the clutch slave cylinder as the biting point of the clutch got closer and closer to the floor until I could no longer select gear as the clutch had gone soft. After replacing with a new clutch slave cylinder and i got about three weeks out of driving the car. For the last week each time i go out to drive the car after it sits over night the clutch has no pressure at all until it is pumped a few times. On the drive home last night the pressure went completed and now it is very difficult to get gear at all.
I have had a look at the slave and there are no leaks, looked at the master and its the same, fluid levels are normal.
Anyone any ideas?
1999 MK2 1.8i S in Silver
Dan_Mosca
Re: Clutch Issue
Postby drumtochty » Tue Mar 03, 2015 10:18 pm
Air in the system!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Re: Clutch Issue
Postby BoabG » Wed Mar 04, 2015 8:47 am
Sounds like you'll have to re-bleed the system.
2004- MX5 Euphonic in Titanium.
BoabG
Bob Gray
Re: Clutch Issue
Postby Dan_Mosca » Wed Mar 04, 2015 2:57 pm
Turns out it was a faulty Slave Cylinder that went into the car....she's in the mechanics right now getting it changed :)
Dan_Mosca
