heated rear window
heated rear window
Postby gallowflat23 » Tue Jan 27, 2015 8:35 pm
while cleaning inside of heated rear window managed to dislodge the 2 mains conections from the glass anybody help with what to use to refix to heating element
gallowflat23
Stan+Sheena Dixon
Re: heated rear window
Postby drumtochty » Tue Jan 27, 2015 11:45 pm
Welcome to the forum.
Try this or search ebay
http://www.halfords.com/motoring/garage ... ter-repair
Postby drumtochty » Wed Jan 28, 2015 12:36 am
Some suggest a blob of araldite after that to reinforce the joint.
Postby gm » Wed Jan 28, 2015 2:38 am
I've used the conductive paint to repair damaged filaments which worked well but if the power cable has become detached, you may need to solder it back on. the trick will be getting enough heat to solder a good connection without cracking the glass. Glue to reinforce afterwards sounds like a good idea though.
Postby gallowflat23 » Wed Jan 28, 2015 2:49 pm
gm wrote:I've used the conductive paint to repair damaged filaments which worked well but if the power cable has become detached, you may need to solder it back on. the trick will be getting enough heat to solder a good connection without cracking the glass. Glue to reinforce afterwards sounds like a good idea though.
have been strongly advised not to try solder thanks anyway
gallowflat23
Stan+Sheena Dixon
Postby gallowflat23 » Wed Jan 28, 2015 2:57 pm
drumtochty wrote:Welcome to the forum.
have been to my local Halfords but they wernt much help but will try other branches plenty about thanks
gallowflat23
Stan+Sheena Dixon
