Bentley W12 Engine Build
Postby drumtochty » Thu Dec 11, 2014 8:35 pm
Re: Bentley W12 Engine Build
Postby iain cooper » Thu Dec 11, 2014 9:15 pm
great video Eddie, definitely hand built !!
Iain
iain cooper
Postby tjay » Fri Dec 12, 2014 11:21 pm
cracking video, best 15 mins I have watched in a bit, cannot believe just how big it is, ditto the brakes and calipers :D :D
tjay
tom + Jen mcginnis
Postby OldSpice » Thu Dec 18, 2014 12:10 pm
Enjoyed that very much.
How clean is that factory?
Basically and it's no secret, that engine is two VAG VR6s merged into one block. These guys sure are Top-Gun "fitters" but that's about it.
My brother-in-law was an RR engine builder in the late 60's & early 70's. He machined a lot of the reciprocating bits with his little team from solid billet and hand-built the mighty 6.7ltr V8's from scratch.
General Motors pistons (apparently) but none the worse for it, as were the autotrans prior to RR tweaks.
Now that was real engine building. It's said no two engines power outputs were ever identical..be that a good or bad thing.
Postby drumtochty » Thu Dec 18, 2014 12:16 pm
Are you sure about that story re the V8????????????????????????????
Forget that, I was thinking it was a GM V8. It was only the auto box and the rear axle that was brought in from the states!
