Left Indicator won't go off
Postby Rod1969 » Sat Sep 20, 2014 7:01 pm
I came out to my mk2 mx5 flashing at me today. The left indicator will not go off. The right indicator works fine as do my hazards. I have read that it might be a relay problem and some recommend swapping the relay that runs the right indicator with the left on to see if that is the problem but that was with a Ford.Is this a case with a Mazda. Could this be the problem? Where do I find the relays. I found the fuses and checked them but can't find the relays.
I have disconnected the battery to stop it running down but really need it to stop winking at me!!! Any help will be most appreciated.
Rod1969
