Meister R
Meister R
Postby zebedee » Sat May 09, 2015 5:19 pm
Just received these, and they look too good to hide away under the car......think I may just drive around with them hanging from the mirror.
zebedee
Re: Meister R
Postby ruggiebloke » Sat May 09, 2015 5:55 pm
Ooft. Pirty.
ruggiebloke
Re: Meister R
Postby marshall » Sat May 09, 2015 6:45 pm
Suspension porn, put it away
marshall
Marshall Pirrie
Re: Meister R
Postby marshall » Sat May 09, 2015 6:52 pm
Is it for a mk3 if so let me know how it rides
marshall
Marshall Pirrie
Re: Meister R
Postby zebedee » Sat May 09, 2015 6:58 pm
marshall wrote:Suspension porn, put it away
Im just currently sitting here stroking them.
marshall wrote:Is it for a mk3 if so let me know how it rides
Yes for MK3 Marshall, which currently looks like this......thinking of using them to go higher.....what do you think? Image
Dave
zebedee
Re: Meister R
Postby marshall » Sat May 09, 2015 7:30 pm
Lol yeah the higher the better
marshall
Marshall Pirrie
Re: Meister R
Postby Purplebug » Mon May 11, 2015 3:19 pm
If you use them at the highest setting then hopefully you can see them in there glory :wink:
Purplebug
Re: Meister R
Postby Sprockutt » Tue May 12, 2015 10:13 am
WANT these for my Mk1. Lovely looking piece of kit.
Sprockutt
Re: Meister R
Postby zebedee » Fri May 15, 2015 4:48 pm
Im SAD!!!! Image
Car went in the garage today to have the coilovers fitted, and after they had fitted 3 without any problem they found the last one had a seized bolt and could not get a replacement until next week.
zebedee
Re: Meister R
Postby marshall » Fri May 15, 2015 6:39 pm
Gutted for you ,you should have gave me a shout I could have fitted them for you
marshall
Marshall Pirrie
Re: Meister R
Postby zebedee » Fri May 15, 2015 6:49 pm
Thanks, would have liked working with you to do them. Only reason I didn't do them myself is I know these jobs can be a pain when you get rusted bolts.
I knew I was leaving it a bit late but I wanted it done for the Ayr run, and I've been away in Northern Ireland all week so today was my first chance to get them done.
The other three look good on the car, and it doesn't look to be sitting too low. Much as I would prefer to go really low, I know from past experience it can be a bit impractical at times. Last mk3 got wedged twice on top of speed humps.
zebedee
Re: Meister R
Postby marshall » Fri May 15, 2015 6:56 pm
Which bolt was being rude and not coming out, I've done a fair few of these now newer and older ones and never really had any issues, really like to know what drive is like as I'm considering too did you go for the s or the r
marshall
Marshall Pirrie
Re: Meister R
Postby zebedee » Fri May 15, 2015 7:00 pm
Think it was one of the concentric adjuster bolts, they said it was quite common with mx5s, as such find it a bit strange they don't hold a few in stock, as they also say they do a lot of alignments on mx5s.
Will let you know, you can have a drive with it as well if you want to try it
zebedee
Re: Meister R
Postby zebedee » Fri May 15, 2015 7:03 pm
Went for the zeta s
zebedee
Re: Meister R
Postby marshall » Fri May 15, 2015 7:04 pm
You can do them without taking them out, I thought that would be the one, on the rear I take it, I always pop out joint comes out no probs so as I don't knock out alignment, when I done my first 5 it didn't need adjusted after fitting, could have got them fitted and worry about bolt later when alignment is carried out
marshall
Marshall Pirrie
Re: Meister R
Postby zebedee » Fri May 15, 2015 7:07 pm
Not sure of the reason. They did show me the one they had trouble with, and said the other front was no problem.
zebedee
Re: Meister R
Postby marshall » Fri May 15, 2015 7:09 pm
Front eh that's strange always been a doodle to me, I'm sure the wait will be worth it
marshall
Marshall Pirrie
Re: Meister R
Postby zebedee » Fri May 15, 2015 7:11 pm
I hope so. With a steel ruler across the top of the tyre the gap to the wing was 6cm rear, and 7.5cm front. They will be going down to approx 2cm
zebedee
Re: Meister R
Postby marshall » Fri May 15, 2015 7:15 pm
Won't look to low then and you always have the option to go a little lower if you choose too
marshall
Marshall Pirrie
Re: Meister R
Postby marshall » Fri May 15, 2015 7:21 pm
I was thinking of going for the R but if yours is any good make save a few quid by going for the S
marshall
Marshall Pirrie
