aerial motor
aerial motor
Postby hold on tight » Sun Nov 09, 2014 7:32 pm
My aerial is stuck (fortunately in the up position) but the motor is running, so it sounds as if there's a stripped gearwheel inside. Has anybody else come accross this? Is it worth trying to fix it, or look for another one. Or just live with it?
hold on tight
Re: aerial motor
Postby gm » Sun Nov 09, 2014 7:42 pm
Sounds like you may need one of these
http://www.autolinkmx5.com/aerial-mast-electric-genuine-mazda-mx-5-mk2-b05a66a30-1061-p.asp
Use the code "mx5nutz" for 5% discount if you do order from Autolink
Re: aerial motor
Postby drumtochty » Sun Nov 09, 2014 8:04 pm
If you are unlucky and you have to strip the motor the black grease gets everywhere.
Yes, i have been there.
Re: aerial motor
Postby OldSpice » Mon Nov 10, 2014 12:37 pm
Same position here..except mind is down.
As Andrew at Autolink explained to me the other day...if you hear a grinding & nashing of teeth (the ariel's..not yours) it'll possibly be the stupid Nylon tooth gear stripped.
TBH, mine can stay down till I get one off a wreck as the cost is horrendous to repair/replace.
Re: aerial motor
Postby Purplebug » Mon May 25, 2015 6:44 am
Mx5 parts sell the genuine mazda mast for £26 or so. Just did mine last night. My one was stuck up but no gear noise. Stripped it and found dirty contacts. Broken mast removed and replaced and now running fine :)
Purplebug
