NB factory windbreaker/soundboard speaker replacement
Postby ard » Thu Mar 31, 2011 9:46 pm
Has anyone with the OEM windblocker/speaker combo on their NB ever tried to replace the speakers? The original ones are terrible, to the point that I have my fader set to barely use them at all - I think they're identical to the tweeters mounted up front.
They're about 2" in size, but I can't find any replacements online that have the same diameter between the mounting holes... any advice?
2004 Mk 2.5 MX-5 1.8 S-VT Sport in Classic Black
ard
Re: NB factory windbreaker/soundboard speaker replacement
Postby ard » Thu Mar 31, 2011 9:52 pm
Clearly, I should have posted this in the ICE forum... can a mod move it please?
ard
Postby The Pram » Fri Apr 01, 2011 7:45 am
Can't answer the question but I would be interest to know as I have installed a roll bar and had to take the soundboard / windbreaker out but I have since squeezed it back in and hold it in place with cable ties (very professional). Now the speakers are wedged up against the seats so no doubt I get no sound out past them now.
Boorachie of Teuchters.
2005 1.8 Arctic edition
2013 2.0 Sport Graphite No177
2015 1.6 Sport Nav
The Pram
Postby IanN » Fri Apr 01, 2011 12:10 pm
ard wrote:Clearly, I should have posted this in the ICE forum... can a mod move it please?
Now done :wink:
2016 Mk4 Icon Special Edition
IanN
Ian Ness
Postby ard » Tue Apr 05, 2011 12:25 am
I've been doing a bit of digging online with limited results.
I've also removed the speakers from the board - they have a square hole pattern with 80mm diagonal, and the cones themselves are ~55mm diameter. They're ~30mm deep, and are marked as 4Ohm 25W drivers.
I can find a whole bunch of speakers online which are between 70-90mm diagonal, but none are exactly 80mm. I suspect that I might have to attack either the new units or the cavity with my Dremel.
These look like potential candidates, or there's a selection on this page which might do the trick. It'd be nice to shoehorn a pair of 3" drivers in there, but I'm not sure there's enough depth. Watch this space!
ard
Postby mooore17 » Sat Nov 12, 2011 10:33 am
Its old topic but anyone knows any other good trick
mooore17
