Clatter' Brig Ford to Drumtochty
Discussion about events organised by the three North of Scotland areas.
[Please do not cross-post]
Postby mgrays » Wed Aug 17, 2011 12:49 pm
The Ford on the wee road from the bottom of the Clatterin' Brig (on South side of Cairn O'Mount) to Auchenblae/Drumtochty is offically closed. The upstream side side of the tarmac has been picked up and lifted onto the downstream side of the tarmac for about 12'. This leaves a 3" step onto the concrete under the tarmac so you can go over it still with care.
The actual Cairn O'Mount from Banchory to Fettercairn is not affected.. just this wee side road.
FYI .. if you are carving around my area; it would only affect if you were trying to come in from Auchenblae and then found it closed after 3 miles.. but hey that is a lot better than when the Cairn is offically closed (30 mile detour) yet it is not :wink:
Re: Clatter' Brig Ford to Drumtochty
Postby allandwf » Wed Aug 17, 2011 7:34 pm
Thanks, I'm sometimes out that way on a run, and usually head back from Aberdeen via Garlogie, Banchory, Fettercairn down to Edzell then down to Forfar. Some nice roads out there.
allandwf
Return to Highland & Moray, Grampian and Tayside
