Amazing home remedies
Post your jokes et al in here.
WARNING: Some users may find content in this forum offensive.
Postby hubba64 » Wed May 09, 2007 8:00 am
1. If you are choking on an ice cube , don't panic. Simply pour a cup of boiling water down your throat and presto! the blockage will be almost instantly removed.
2. Clumsy? Avoid cutting yourself while slicing vegetables by getting someone else to hold them while you chop away.
3. Avoid arguments with the Mrs. about lifting the toilet seat by simply using the sink.
4. For high blood pressure sufferers: simply cut yourself and bleed for a few minutes, thus reducing the pressure in your veins. Remember to use a timer.
5. A mouse trap, placed on top of your alarm clock, will prevent you from rolling over and going back to sleep after you hit the snooze button.
6. If you have a bad cough, take a large dose of laxatives, then you will be afraid to cough!
7. Have a bad toothache? Smash your thumb with a hammer and you will forget all about the toothache.
8. Sometimes, we just need to remember what the rules of life really are: You only need two tools - WD-40 and Duct Tape. If it doesn't move use the WD-40. If it shouldn't move and does, use the duct tape.
Image Image Image Image
hubba64
Return to Jokes and Humour
